12 years agoNIOS II 32 bit data master -> Avalon MM PCIe 64 bit TX slave
I had a system working where the DMA controller ( 64 bit ) was reading and writing to the TX port of the PCIe TX port . I now have a situation where I want the NIOS II data master ( 32 bit ) to r...
12 years agoIt is certainly much easier if you use a single BAR to access all Avalon slaves, and make the base of the addressed area include Avalon address zero.
Basically the PCIe slave block removes the high address bits from the PCIE address, and then (effectively) substitutes a different (fixed for each BAR) set of high address bits. The sopc code had some strange restrictions on where BARs could address, qsys may have the similar ones. I suspect that they've tried to make it 'simple' and only succeeding in making it confusing! The nios cpu (without mmu) uses the high address bit to mean 'cache bypass' - so it can only generate 31bit addresses (including the address bits that convert to byte enables). The PCIe master interface is rather horrid - the requirements don't really match that of an Avalon slave. For single-cycle pio requests I'd be tempted to write an Avalon slave that can latch the required 64bit pcie address and data, and then be told to perform a single master transfer - the poll the slave interface for when the request finishes. (A bit like a very degenerate dma controller.) For longer transfers a dma controller that can read avalon data and the burst write to the pcie slave (or burst read the pcie slave and write to avalon addresses) would be useful - with the nios cpu polling for completions and managing any request queue. But I can't immediately see how to use any of the existing dma controllers for that purpose.
