13 years agoNIOS II 12.0 Installation and Tutorialproblems
I tried the tutorial "tut_sopc_introduction_vhdl" and "myfirstniosii.pdf". Both are on a System CD from terasIC and both don't work on my PC. When I try the Altera Monitor Program Tutorial all is okay (I can compile and load the demo programm basic computer de2-115). But when I try the sopc introduction tutorial I got these message in the Info&Error Box: Info: ******************************************************************* Info: Running Quartus II 32-bit Programmer Info: Version 12.0 Build 178 05/31/2012 SJ Web Edition Info: Copyright (C) 1991-2012 Altera Corporation. All rights reserved. Info: Your use of Altera Corporation's design tools, logic functions Info: and other software and tools, and its AMPP partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Altera Program License Info: Subscription Agreement, Altera MegaCore Function License Info: Agreement, or other applicable license agreement, including, Info: without limitation, that your use is for the sole purpose of Info: programming logic devices manufactured by Altera and sold by Info: Altera or its authorized distributors. Please refer to the Info: applicable agreement for further details. Info: Processing started: Sun Jun 02 16:33:07 2013 Info: Command: quartus_pgm -c "USB-Blaster [USB-0]" -m jtag -o P;C:\altera_tutorials\sopc_tutorial_vhdl\light.sof Info (213045): Using programming cable "USB-Blaster [USB-0]" Info (213011): Using programming file C:/altera_tutorials/sopc_tutorial_vhdl/light.sof with checksum 0x00562AB9 for device EP4CE115F29 Info (209060): Started Programmer operation at Sun Jun 02 16:33:09 2013 Info (209016): Configuring device index 1 Info (209017): Device 1 contains JTAG ID code 0x020F70DD Info (209007): Configuration succeeded -- 1 device(s) configured Info (209011): Successfully performed operation(s) Info (209061): Ended Programmer operation at Sun Jun 02 16:33:15 2013 Info: Quartus II 32-bit Programmer was successful. 0 errors, 0 warnings Info: Peak virtual memory: 181 megabytes Info: Processing ended: Sun Jun 02 16:33:15 2013 Info: Elapsed time: 00:00:08 Info: Total CPU time (on all processors): 00:00:09 Compiling source files... nios2-elf-as --gstabs -I C:/altera/12.0/quartus/../nios2eds/components/altera_nios2/sdk/inc -I C:/altera_tutorials/sopc_tutorial_vhdl C:/altera_tutorials/sopc_tutorial_vhdl/app_software/lights.s -o C:/altera_tutorials/sopc_tutorial_vhdl/lights.s.o C:/altera_tutorials/sopc_tutorial_vhdl/app_software/lights.s:0: Warning: end of file not at end of a line; newline inserted Linking... nios2-elf-ld --defsym nasys_program_mem=0x1000 --defsym nasys_data_mem=0x1000 --section-start .exceptions=0x1020 --section-start .reset=0x1000 -e _start -u _start --script c:/altera/12.0/University_Program/Monitor_Program/build/nios_as_build.ld -g -o C:/altera_tutorials/sopc_tutorial_vhdl/lights.elf C:/altera_tutorials/sopc_tutorial_vhdl/lights.s.o ELF generated at C:\altera_tutorials\sopc_tutorial_vhdl\lights.elf. nios2-elf-objcopy -O srec C:/altera_tutorials/sopc_tutorial_vhdl/lights.elf C:/altera_tutorials/sopc_tutorial_vhdl/lights.srec SREC generated at C:\altera_tutorials\sopc_tutorial_vhdl\lights.srec. There are no Nios II CPUs with debug modules available which match the values specified. Please check that your PLD is correctly configured, downloading a new SOF file if necessary. When I want to run the Hallo World Program for the tutorial myfirstniosii.pdf I can't get a connection between my PC and the board. There is something what I don't understand and what is confusing me. I also have problems when I don't use the stand alone programmer from Altera. In a thread I read that somebody has a similar problem and got the same message. Someone told him to execcute jtagconfig -n and post the outtake. My outtake is: [NiosII EDS]$ jtagconfig -n 1> USB-Blaster [USB-0] 020F70DD EP3C120/EPCE115 Thanks in advance!3 Replies
I have some "Warnings" when I compile the project in Quartus II:
Does it matter? Thanks for any help!Warning (20013): Ignored assignments for entity "nios_system" -- entity does not exist in design Warning (20014): Assignment for entity set_global_assignment -name IP_TOOL_NAME sopc -entity nios_system -qip nios_system.qip was ignored Warning (20014): Assignment for entity set_global_assignment -name IP_TOOL_VERSION 12.0 -entity nios_system -qip nios_system.qip was ignored Warning (20014): Assignment for entity set_global_assignment -name IP_TOOL_ENV sopc -entity nios_system -qip nios_system.qip was ignored - Altera_Forum
I changed the processor to NiosII/e and Debug level 1, because I use Web Edition and I have no licence. But some say that when the DE2-115 is connected via USB to my host PC then I can use also the NIOS II Processor /f. I generate the system in SOPC Builder and compile in QuartusII. Now, I load the sof file succesfully to the fpga and with the Altera Monitor Program I compile and load the files. But it is the same error. I think a licence can't be the problem. There are no Nios II CPUs with debug modules available which match the values specified. Please check that your PLD is correctly configured, downloading a new SOF file if necessary. I use Quartus 12.0 Web Edition, Nios II EDS 12.0, Nios Legacy Tools 12.0 with SP2, Quartus II Programer 12.0 and Altera Monitor Program 12.0. OS is Windows 7 Home Premium 64bit. - Altera_Forum
Some here in the forum wrote that it helps when they delete the sof file and the ptf file. Then I compile new files. But still the same error message in the Altera Monitor Program.
