11 years agoNios IDE doesn't launch. How to change a path?
Hello! Nios 9.1 IDE doesn't launch. There is an error "a java runtime environment or java development kit must be available in order to run nios2-ide. No Java virtual machine was found after searc...
10 years agoHi.
The error message said that there is not any java virtual machine installed in your computer. Do you have a Java installation in your PC? If not, you need to download a jre installation file and install it. I recommend you the JRE 1.6.0_45 version. Please, let me know if you can solve your issue.
