16 years agoNios crashes when reading from the DDR2
Hi, I'm trying to setup the DDR2 as a frame buffer for streaming to a display. Currently, I am able to write and read pixels to and from the off-chip DDR2 and communicate with custom ha...
16 years agoHaha. Well, thanks for helping me out. I'm learning a lot trying to troubleshoot this.
My palm just hit my head because I realized a few pins were not connected this morning when I was testing it. It's the stupidest thing. I'm nowhere near the board right now, but I'll fix it and test it out later. I noticed I was getting a warning about the ddr pll clk[2] signal not being used. So, I'll see if that warning goes away when I fix the pin assignments. I'm not sure how they ever got deleted in the first place. Also, for the DE3 board, there's a voltage regulator circuit for each of the 4 different regions where things are connected. It's the first thing you define when you start the design (which for me was a few months ago). A while ago, I commented it out, but the DDR2 takes 1.8 V instead of the default 3.3 V. I'll let you know if it works. Andrew
