16 years agoNios crashes when reading from the DDR2
Hi, I'm trying to setup the DDR2 as a frame buffer for streaming to a display. Currently, I am able to write and read pixels to and from the off-chip DDR2 and communicate with custom ha...
16 years agoThe design uses multiple clock domains, so I've implemented a dual-register reset synchronizing circuit for each clock domain's reset in order to have synchronous reset removal. For the DDR2, the "global_reset_n_to_the_ddr2" port should be getting the reset from the same domain as its input global osc_clock, correct?
I'm compiling the design you suggested. thanks, Andrew
