8 years agoNIOS can not boot from EPCS ?!!!
Hi guys , im trying to make the NIOS II boot from the same EPCS where the configuration is stored. Im using Quartus 13 and it has only the legacy serial flash controller. The documentation says t...
8 years ago --- Quote Start --- Hello everyone, I am facing similar problem. I have a NIOS II E based system and I created the .jic file and loaded into EPCQ64 and booted the system without any problem. Now I changed NIOS II E to NIOSE II F as I need faster processing. I compiled the project and it works fine and even imporved. But when i genereate the hex file for NIOS II F version and so the .jic and download it to EPCQ64, the system doesnt boot up ? As I said, it works fine and boots up with NIOS II E and NOT with NIOS II F. Any idea suggestion ? --- Quote End --- Can some one help me as I am still unable to resolve the issue ?
