8 years agoNIOS can not boot from EPCS ?!!!
Hi guys , im trying to make the NIOS II boot from the same EPCS where the configuration is stored. Im using Quartus 13 and it has only the legacy serial flash controller. The documentation says t...
8 years agoHi
Is there any default program in epcs device?can you see default program running? OR Can you try to load .pof with help of flash loader. Which board you are using(part number& family)? Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
