8 years agoNIOS can not boot from EPCS ?!!!
Hi guys , im trying to make the NIOS II boot from the same EPCS where the configuration is stored. Im using Quartus 13 and it has only the legacy serial flash controller. The documentation says t...
8 years agoHi Muhammad,
1.Have you tried by loading sof and run as hardware? does it work.?(to check the design part) 2.Try to load .jic for simple program like hello world project. (to check the hardware part) 3.Are you using development board Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
