13 years agoNIOS beginner- interfacing with hardware module
Hello! I am an absolute beginner in NIOS and would really appreciate if someone can help me with some advice with the following: I have a working hardware module synthesized in FPGA. I actually...
13 years ago --- Quote Start --- You can use system console instead of a NIOS, to execute the necessary reads/writes. You would write a program that executes on the PC in a TCL interpreter instead of writing a program that executes on the NIOS. The construction of your hardware component and it's integration to the hardware is basically the same. But if your needs are even more modest than that, and just need to see "something" control your new component, you can also use the In-System Sources and Probes tool. --- Quote End --- I am using the signal-tap now and everything looks good. I just need a way to demo my project and show that my hardware is functional. I guess, as I don't have much time, I might go for system console as it seems easier to pick-up. In that case, I need to have have a slave interface for my hardware and connect it with jtag to avalon master module in qsys. Am I right?
