12 years agoNios as slave with spi
Hello guys, I'm writing beacause I need some suggestions.. I have an FPGA running a NIOS2 processor. This processor will be interrogated by a master peripheral with the SPI protocol. I know tha...
12 years agoFor example port defs in your vhdl (I use vhdl) should be modified as (disable pio's that become input or outputs and add miso mosi sclk scs, following example is for master spi)
entity yourprog is port ( clk_clk : in std_logic := '0'; -- clk.clk leds_export : out std_logic_vector(7 downto 0); -- leds.export --input1_export : in std_logic_vector(7 downto 0) := (others => '0'); -- input1.export --output1_export : out std_logic_vector(7 downto 0); -- output1.export --spi_wr_export : out std_logic_vector(31 downto 0); -- spi_wr.export --spi_rd_export : in std_logic_vector(7 downto 0) := (others => '0') -- spi_rd.export MOSI : out std_logic:='0'; MISO : in std_logic; SCLK : out std_logic:='0'; SCS : out std_logic:='1' ); end entity yourprog; Then you should define those disabled variables as signals to be used in your process... signal input1_export : std_logic_vector(7 downto 0) := (others => '0'); -- input1.export signal output1_export : std_logic_vector(7 downto 0); -- output1.export signal spi_wr_export : std_logic_vector(31 downto 0); -- spi_wr.export signal spi_rd_export : std_logic_vector(7 downto 0) := (others => '0'); -- spi_rd.export Then you can add a process depending on your status... (following code is my master spi code, it uses a counter named counter_spi and increased by clk) process (clk_clk) begin if(output1_export(0) = '1' and output1_export(0)'event) then input1_export(0) <= '1'; end if; if (clk_clk = '1' and clk_clk'event and input1_export(0) = '1') then counter_spi <= counter_spi + '1'; end if; if (counter_spi = "1111111111") then input1_export(0) <= '0'; counter_spi <= "0000000000"; end if; end process; process (counter_spi) begin if (counter_spi(1) = '1' and counter_spi(1)'event) then --yazma if(counter_spi(9)='0' and spi_wr_export(10) = '1' and counter_spi(3)='0') then MOSI <= spi_wr_export(31-conv_integer(counter_spi(8 downto 4))); spi_rd_export <= X"55"; end if; --okuma if(counter_spi(9)='0' and spi_wr_export(10) = '0') then if(counter_spi(8 downto 4)<"11000" and counter_spi(3)='0') then MOSI <= spi_wr_export(31-conv_integer(counter_spi(8 downto 4))); end if; if(counter_spi(8 downto 4)>="11000" and counter_spi(3)='1') then spi_rd_export(7-conv_integer(counter_spi(6 downto 4))) <= MISO; --spi_rd_export(7-conv_integer(counter_spi(6 downto 4))) <= spi_wr_export(31-conv_integer(counter_spi(6 downto 4))); end if; end if; SCLK <= counter_spi(3) and (not counter_spi(9)); if (counter_spi(9) = '1' and counter_spi(5) = '1') then SCSn <= '1'; end if; if (counter_spi(9) = '0' and input1_export(0) = '1') then SCSn <= '0'; end if; input1_export(1) <= RDY; input1_export(2) <= Intn; input1_export(3) <= counter_spi(3) and (not counter_spi(9)); RSTn <= output1_export(2); end if; end process; You should create your own spi process to act as a slave, instead of using a counter depending on internal clock, you should use the external clock supplied by your external spi master.
