JLee25
Contributor
6 years agoNios 2 Boot Issue
Hi, I am using Cyclone 10 GX for an embedded project with Nios 2. Quartus Pro 19.2 + C 10 GX + MT25QU256 For unknown reason, the Nios 2 did not boot. I have to manually download the elf again thr...
- 6 years ago
Hi, Johnson
Can we close this ? you may open a new one if you still have inquiry and want to follow up.
Eric
EricMunYew_C_Intel
6 years agoHi, Johnson
Can you try to run timing analysis and check if you have no timing violation ?
You may constraint the Nios core, GQSPI controller II and other IPs which are timing critical.
Eric
