Nios 2 Boot Issue
- 6 years ago
Hi, Johnson
Can we close this ? you may open a new one if you still have inquiry and want to follow up.
Eric
Hi Eric,
Please download the zip file and check the contents inside.
Shared folder include the jic file with both FPGA image and Nios 2 flash.
Qsys is the controller I am using now, Generic Quad SPI running at 25MHz.
I checked the clock frequency on board.
From the linker, Nios2 will run on DDR.
Then I use qspi flash controller to read and print the content in device at address 0x0100_0000.
Include check the device ID.
This is where the APP stored.
JIC is the shared jic file that I use reader to get the raw data.
You can compare it with nios2_shell_print, they are of the same.
Therefore I am confirm the programming to flash and the content inside should be fine.
Unfortunately, the program is not running and I have to download the elf to make it work.
The problem is bootcopier or the converted file?
BRs,
Johnson
Hi Eric,
Good day!
Do you have any update on the issue after receiving my shared files?
Please let me know.
Thank you!
BRs,
Johnson
