JLee25
Contributor
6 years agoNios 2 Boot Issue
Hi, I am using Cyclone 10 GX for an embedded project with Nios 2. Quartus Pro 19.2 + C 10 GX + MT25QU256 For unknown reason, the Nios 2 did not boot. I have to manually download the elf again thr...
- 6 years ago
Hi, Johnson
Can we close this ? you may open a new one if you still have inquiry and want to follow up.
Eric
EricMunYew_C_Intel
6 years agoHi, Johnson
Would you try this, when you generate the .hex from .elf using mem_init_generate utility in your EDS, ie right click on project in Project Explorer, and Make Targets > Build.
After you get your .hex under mem_init folder, also look for meminit.qip, and add this meminit.qip to your Quartus project and then generate the .sof.
Next when you convert the programming file, just convert this .sof to .jic or .pof, and then program this .jic or .pof into your flash.
Eric
