JLee25
Contributor
6 years agoNios 2 Boot Issue
Hi, I am using Cyclone 10 GX for an embedded project with Nios 2. Quartus Pro 19.2 + C 10 GX + MT25QU256 For unknown reason, the Nios 2 did not boot. I have to manually download the elf again thr...
- 6 years ago
Hi, Johnson
Can we close this ? you may open a new one if you still have inquiry and want to follow up.
Eric
EricMunYew_C_Intel
6 years agoHi, Johnson
Then you may use auto or 0x00000020 as start address.
For the .hex generation, may I know what problem you face when you generate .hex from .elf in Quartus 19.2 ?
At the meantime, I will look at the manual method you use to convert .elf to .hex and will get back to you.
Eric
