JLee25
Contributor
6 years agoNios 2 Boot Issue
Hi, I am using Cyclone 10 GX for an embedded project with Nios 2. Quartus Pro 19.2 + C 10 GX + MT25QU256 For unknown reason, the Nios 2 did not boot. I have to manually download the elf again thr...
- 6 years ago
Hi, Johnson
Can we close this ? you may open a new one if you still have inquiry and want to follow up.
Eric
JLee25
Contributor
6 years agoHi Eric,
Thank you for getting back,
From my post above at the last image, FPGA will use flash up to 0x00AEFFFF.
And Nios starts from 0x010000 to 0x0107DFFFF.
And Link setting in BSP editor are left unchecked as above..
Would it be possible caused by the elf to hex conversion?
As in Q19.2, the tool has problem that I have to do it manually.
And I am not sure this tool will cover Micro Flash or not..
BRs,
Johnson
