JLee25
Contributor
6 years agoNios 2 Boot Issue
Hi, I am using Cyclone 10 GX for an embedded project with Nios 2. Quartus Pro 19.2 + C 10 GX + MT25QU256 For unknown reason, the Nios 2 did not boot. I have to manually download the elf again thr...
- 6 years ago
Hi, Johnson
Can we close this ? you may open a new one if you still have inquiry and want to follow up.
Eric
EricMunYew_C_Intel
6 years agoHi, Johnson
Can you check if the reset vector offset is larger than the FPGA image size ?
For instance, if the size of the FPGA image is estimated to be less than 0x01E00000, you can set the Nios II Reset Vector offset to 0x01E00000 in Qsys, which is also the start of the boot copier.
Also make sure that All settings in Settings.Advanced.hal.linker in BSP editor are left unchecked.
Eric
