10 years agoNIOS + Pipeline Bridge
How can someone make memory imported through an MM pipeline bridge visible in Eclipse/NIOS? On BSP editor I can only see the on-chip memory. I'd like to place .rwdata .rodata on that section up...
10 years agoOh so it's a different .tcl file. I'm referring to the TCL file you create through "File... export hardware as tcl". Is that the same?
Then the qsys project is loaded up in top/verilog. Does this tcl file get parsed again in this specific case?
