10 years agoNIOS + Pipeline Bridge
How can someone make memory imported through an MM pipeline bridge visible in Eclipse/NIOS? On BSP editor I can only see the on-chip memory. I'd like to place .rwdata .rodata on that section up...
10 years agoThe tcl file is for Qsys, you don't add it to your project. When Qsys adds the component it parses the tcl file to understand what it should look like. When you generate the HDL for Qsys it once again parses the tcl file to work out which files it needs and how to make the connections, as well as instructions on how to make the .sopcinfo file (e.g. embeddedsw assignments).
