10 years agoNIOS + Pipeline Bridge
How can someone make memory imported through an MM pipeline bridge visible in Eclipse/NIOS? On BSP editor I can only see the on-chip memory. I'd like to place .rwdata .rodata on that section up...
10 years agoIf you modify the sopcinfo, it will be overwritten every time you re-generate the Qsys file. You need to update at the pipeline_bridge_hw.tcl. Or another way is to make a copy of the pipeline_bridge folder can find somewhere in your $QUARTUS_INSTALL/ip/altera/merlin/altera_avalon_mm_bridge to your Qsys directory and then modify the hw.tcl.
