10 years agoNIOS + Pipeline Bridge
How can someone make memory imported through an MM pipeline bridge visible in Eclipse/NIOS? On BSP editor I can only see the on-chip memory. I'd like to place .rwdata .rodata on that section up...
10 years agoOne way you can try is by creating virtual memory via the nios2-bsp-editor at the linker script tab. The virtual memory should contain the information of the pipeline bridge, ie base address/size.
