15 years agoNIOS + DE2 + Flash Memory + Errors
I created a new project with a SOPC builder system with the following modules: NIOS II/e JTAG UART Avalon Tristate Bridge Flash Memory Interface (CFI) The CFI is connected ...
15 years agoNever mind the exception vector, what about the program data areas and stack!
Indeed, although it is probably technically possible to execute code directly from flash, the normal boot procedures copy the code from flash into RAM (internal memory or external SRAM/SDRAM/DDR).
