Nios® II EDS WSL and Ubuntu versions
- 4 years ago
We currently have no support for Windows 11 yet, as it is still recommended to use Linux environment..
Regarding the support, you may refer to:
https://www.intel.com/programmable/technical-pdfs/726952.pdf#page=7
As of today, we have no update regarding the future support to switch to WSL 2 nor Ubuntu 20.04.
We do recommend users to use Linux environment for better future experience.
Hi, thank you for the answer.
Another solution could be to use NIOS V instead of NIOS II. Could NIOS V be implemented on DE10-Lite card ?
- LFrin4 years ago
Hi, did you try wsl version 1 with Ubuntu 20.04 lts? The Nios II EDS runs fine at my machine with this Ubuntu version. I think the new Nios V is only supported by the Quartus Prime Pro version.
- ETang24 years ago
Hi, no i did not try. I will test but i use win11 + wsl version 2 ...
About NIOS V, you are right it is only supported by the pro version which is not available for MAX10.
