15 years agoNicheStack Wont Connect to Server
Hello everyone, I'm trying to set up some TCP communications between a PC and this DE2-115 board. When I fire up the system I get this: --- Quote Start --- InterNiche Porta...
15 years agoWell, the problem is most definitely on the dev board as I suspected originally.
I fired up Netcat and was able to connect to the server no problem. Anyone see anything wrong with my code? Its pretty standard stuff.. The dev board is ping-able and retrieves IP address via DHCP...
