12 years agoNicheStack - changing IP address without rebooting
Hi, is there a way of changing IP address of the Nios2 without rebooting the whole Nios? Looking through the sources of iniche I can see there is only a alt_iniche_init() procedure, but nothi...
10 years ago --- Quote Start --- I believe you're looking for ni_set_config(). See net.h and iface.c in the iniche files.
/* FUNCTION: ni_set_config()
* set IP address and subnet for a particular device.
* PARAM1: NET ifp
* PARAM2: struct niconfig_0 * cfg
* RETURNS: 0
--- Quote End --- the proposed solution worked just fine until I realized I need the possibility to change the gateway as well. Are you aware of any such function to allow me that?
