15 years agoNewbie regarding NIOS - can I mix VHDL with NIOS in Cyclone III
Hello, I've been using Altera CPLDs and FPGAs strictly with VHDL code. I just learned about NIOS options for the chips. If I implement a NIOS processor in my Cyclone III, can I still run independe...
15 years ago --- Quote Start --- Just to be sure, you describe solutions where the NIOS processor interfaces with the "discrete" VHDL implementations. Can the VHDL code perform its intended hardware tasks independent of the NIOS processor and its actions? --- Quote End --- Yes. For example, you can have an SOPC system defined by the top-level design file sopc_system.vhd and then completely independent logic in independent.vhd, and then put both components in a top_level.vhd file, with no signals going between them, and the two systems are completely independent. The two systems can share clock and reset. Of course, once you have a processor in the system, and it communicates with the outside world, then connecting control and status bits between sopc_system.vhd and independent.vhd can be very convenient. Cheers, Dave
