20 years agoNew component never compiles in Quartus II
Hi all,
after some help from Mike DeSimone (thanks!) I created a new component in SOPC builder from this Verilog file:module ClockGen
input clock,
input reset,
input chipselect,
input write,
input writedata,
output reg clockout
reg count, limit;
always @(posedge clock, posedge reset)
if(reset) begin
count <= 0;
limit<= 0;
clockout <= 0;
end
else begin
if(limit == 0)
clockout <= 0;
else if(count == limit) begin
count <= 0;
clockout <= ~clockout;
end
else
count <= count + 1;
if(chipselect && write)
limit<= writedata;
end
endmodule ---which should function as hardware clock generator. I saved this code into hw_clk.v file and added to User Logic components in SOPC builder as ClockGen component. Then I instantiated it in my system as AD_CLK_HW component and re-generated the system. Until here everything went fine, but when I refresh the .bdf file in Quartus II and start compilation, I get this error: <div class='quotetop'>QUOTE </div> --- Quote Start --- Error: Node instance "the_ClockGen" instantiates undefined entity "ClockGen"[/b] --- Quote End --- Here the compilation stops. I received some feedback from Mike again to resolve the problem by instantiating the component in the SOPC builder under different name, but it hasn't helped at all. I would really appreciate any help with this problem....No RepliesBe the first to reply
