15 years agoNetwork speed between to 2 processors
I have an interesting issue that i can't get to the bottom of. So i have written software to transmit data at a consistent 32Mbps to a Windows PC this works well. Occasionally i see some delay in sen...
15 years agoIt might then be worth looking at whether the TCP stack is actually ever doing any retries - and then try to track down where the packets get dropped. If you can't buffer enough data to allow for a retry it might be better to use UDP - and possibly some simple, fast, retransmit algorythm.
Guessing, it might be that the receiver discards packets when they are very close together - and the PC bridge manages to separate them.
