15 years agoNetwork speed between to 2 processors
I have an interesting issue that i can't get to the bottom of. So i have written software to transmit data at a consistent 32Mbps to a Windows PC this works well. Occasionally i see some delay in sen...
15 years agoIf you can use a hub or a switch with a promiscuous port, try to use that instead. It is indeed possible that the PC acting as a bridge changes the TCP streams in some way. It depends on how the bridging is done.
