15 years agoNetwork speed between to 2 processors
I have an interesting issue that i can't get to the bottom of. So i have written software to transmit data at a consistent 32Mbps to a Windows PC this works well. Occasionally i see some delay in sen...
15 years agoThe plot thickens!!!
I set up my PC to act as bridge so i could use wireshark to monitor the data between the controller boards. In this configuration it appears to work as well. Meaning that only when connected together do they have a problem. I had a look at the window size and couldn't see anything alarming and all checksums and acks appear to be there. Is there anything particular i need to look for. TCP is not my area of expertise. Maybe the PC's adapters are correcting something? But i would have hoped wireshark might have flagged it. Cheers Tim
