15 years agoNetwork speed between to 2 processors
I have an interesting issue that i can't get to the bottom of. So i have written software to transmit data at a consistent 32Mbps to a Windows PC this works well. Occasionally i see some delay in sen...
15 years agowhen I had the TCP window size problem the throughput depended a lot an what the board was connected to. Even changing from Windows to Linux on the PC changed the results. But even if it isn't a window problem, having a look at the packets could give indications about what's wrong.
