15 years agoNetwork speed between to 2 processors
I have an interesting issue that i can't get to the bottom of. So i have written software to transmit data at a consistent 32Mbps to a Windows PC this works well. Occasionally i see some delay in sen...
15 years agoHi Daixiwen,
I'll try and bridge the connection across my network cards and see if i can put a board on each side to see what goes on. The strange thing as i said is that the two boards seem to be able to Tx and Rx with Windows well. Its only when connected together i get the problem. The through put for Tx is a fixed 32Mbps and the Rx is capable of nearly 90Mbps flat out. I'll bridge the adapters and see if wireshark has any leads. Thanks Tim
