15 years agonet-snmp mib files
Hello guys......
i using snmp in uClinux .....it works with the default mibs but i need to do my own mib file ....... anybody knows how can i do that???............ one exemple how can i monitore a peripherial..... thanks Franz Wagner15 Replies
Hi
i'm interested in compiling my own MIB in uclinux.. my snmp works fine but im not able to add my own MIB .. i followed the net-snmp tutorial but no avail ... regards Khushboo - Altera_Forum
hello Mr khushboo_q,
I'm sorry for the delay in reply........ to do you ow mib first you need to write your FILE-MIB.txt this file is used to generate a c skeleton... and look like this
now you need a linux machine to walk away...... install net-snmp .... and put your mib at mibs directory /opt/net-snmp/mibs and run mib2c $mib2c LINEAR-MIB.txt:linearProject this generate two files : linearProject.h and linearProject.c ...... you need modify the .c file to do what you need....... and put this file at nios2-linux/uClinux-dist/user/net-snmp/net-snmp-5.2.1/agent/mibgroup add your mib at menuconfig and voila..... good luck Franz WagnerLINEAR-MIB DEFINITIONS ::= BEGIN IMPORTS NOTIFICATION-TYPE, MODULE-IDENTITY, enterprises, OBJECT-TYPE, Counter32, Integer32, Gauge32 FROM SNMPv2-SMI DisplayString, TruthValue FROM SNMPv2-TC ; tsoipProject MODULE-IDENTITY LAST-UPDATED "201105130000Z" ORGANIZATION "LINEAR Equipamentos Eletronicos S/A." CONTACT-INFO "Contact: Franz Wagner Postal: LINEAR Equipamentos Eletronicos S/A, Praca Linear sn, Santa Rita do Sapucai, MG, Brasil, Web: www.linear-tv.com Email: [email protected]" DESCRIPTION "Rev. 1.33" ::= { linear 8 } linear OBJECT IDENTIFIER ::= { enterprises 25026 } -- top level MIB headings of the LAD MIB tsoipTraps OBJECT IDENTIFIER ::= { tsoipProject 0 } tsoipSystem OBJECT IDENTIFIER ::= { tsoipProject 1 } tsoipTrapInfo OBJECT IDENTIFIER ::= { tsoipProject 2 } -- LAD System Information tsoipTables OBJECT IDENTIFIER ::= { tsoipSystem 1 } -- ----------------------------------------- -- TX Table -- ----------------------------------------- txTable OBJECT-TYPE SYNTAX SEQUENCE OF LinearTxEntry MAX-ACCESS not-accessible STATUS current DESCRIPTION "Tabelas com informacoes de Transmissao e Recepcao." ::= { tsoipTables 1 } linearTxEntry OBJECT-TYPE SYNTAX LinearTxEntry MAX-ACCESS not-accessible STATUS current DESCRIPTION "Tabela de Transmissao." INDEX { linearTxId } ::= { txTable 1 } LinearTxEntry ::= SEQUENCE { linearTxId Integer32, linearTxIp1 Integer32, linearTxIp2 Integer32, linearTxIp3 Integer32, linearTxIp4 Integer32, linearTxPort Integer32, linearTxencap DisplayString, linearTxpacket Integer32, linearTxFec DisplayString, linearTxFecV DisplayString, linearTxEthBps Integer32 } linearTxId OBJECT-TYPE SYNTAX Integer32 (1..10) MAX-ACCESS not-accessible STATUS current DESCRIPTION "Index da Tabela." ::= { linearTxEntry 1 } linearTxIp1 OBJECT-TYPE SYNTAX Integer32 (1..255) MAX-ACCESS read-write STATUS current DESCRIPTION "1 octeto do IP de Destino" ::= { linearTxEntry 2 } linearTxIp2 OBJECT-TYPE SYNTAX Integer32 (1..255) MAX-ACCESS read-write STATUS current DESCRIPTION "2 octeto do IP de Destino." ::= { linearTxEntry 3 } linearTxIp3 OBJECT-TYPE SYNTAX Integer32 (1..255) MAX-ACCESS read-write STATUS current DESCRIPTION "3 octeto do IP de Destino" ::= { linearTxEntry 4 } linearTxIp4 OBJECT-TYPE SYNTAX Integer32 (1..255) MAX-ACCESS read-write STATUS current DESCRIPTION "4 octeto do IP de Destino" ::= { linearTxEntry 5 } linearTxPort OBJECT-TYPE SYNTAX Integer32 (1..65525) MAX-ACCESS read-write STATUS current DESCRIPTION "Porta de Destino" ::= { linearTxEntry 6 } linearTxencap OBJECT-TYPE SYNTAX DisplayString MAX-ACCESS read-write STATUS current DESCRIPTION "Encapsulamento RTP ou UDP" ::= { linearTxEntry 7 } linearTxpacket OBJECT-TYPE SYNTAX Integer32 (1..7) MAX-ACCESS read-write STATUS current DESCRIPTION "N de pacotes ts em cada pacote IP" ::= { linearTxEntry 8 } linearTxFec OBJECT-TYPE SYNTAX DisplayString MAX-ACCESS read-write STATUS current DESCRIPTION "FEC habilitado ou desabilitado" ::= { linearTxEntry 9 } linearTxFecV OBJECT-TYPE SYNTAX DisplayString MAX-ACCESS read-write STATUS current DESCRIPTION "Valor do Fec" ::= { linearTxEntry 10 } linearTxEthBps OBJECT-TYPE SYNTAX Integer32 MAX-ACCESS read-only STATUS current DESCRIPTION "Taxa de transmissao na saida ETH" ::= { linearTxEntry 11 } -- ----------------------------------------- -- LAD traps -- ----------------------------------------- tsoipRefreshAlarm NOTIFICATION-TYPE OBJECTS {refreshTrap} STATUS current DESCRIPTION " Trap issued when an alarm is triggered. " ::= { tsoipTraps 1 } -- ----------------------------------------- -- LAD Trap Info: varbinds sent with traps -- ----------------------------------------- refreshTrap OBJECT-TYPE SYNTAX Integer32 MAX-ACCESS accessible-for-notify STATUS current DESCRIPTION "This is the Id (row number in the ladAlarmTable) of the zone generating the alarm." ::= { tsoipTrapInfo 1 } END - Altera_Forum
Hi all,
I have a system with a nios2 and a network interface (Altera Triple speed Ethernet MAC). I use 2.6.30 kernel on my board and net-snmp 5.2.1. I can see my network interfaces using ifconfig : --- Quote Start --- /# ifconfig eth0 Link encap:Ethernet HWaddr 00:15:12:00:15:88 inet addr:192.168.0.110 Bcast:192.168.0.255 Mask:255.255.255.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:1400 errors:0 dropped:681 overruns:0 frame:0 TX packets:400 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:205531 (200.7 KiB) TX bytes:33239 (32.4 KiB) Base address:0x400 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 UP LOOPBACK RUNNING MTU:16436 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) --- Quote End --- So the systems know interface statistics. But I wonder why net-snmp is not able to handle these statistics automatically. I have the following : --- Quote Start --- /# snmpwalk -v 1 -c public 192.168.0.110 1 iso.3.6.1.2.1.1.1.0 = STRING: "XXX" iso.3.6.1.2.1.1.2.0 = OID: ccitt.1 iso.3.6.1.2.1.1.3.0 = Timeticks: (115) 0:00:01.15 iso.3.6.1.2.1.1.4.0 = STRING: "System Contact (configurable)" iso.3.6.1.2.1.1.5.0 = STRING: "System Name (configurable)" iso.3.6.1.2.1.1.6.0 = STRING: "System Location (configurable)" iso.3.6.1.2.1.1.7.0 = INTEGER: 2 iso.3.6.1.2.1.1.8.0 = Timeticks: (7) 0:00:00.07 iso.3.6.1.2.1.1.9.1.2.1 = OID: iso.3.6.1.6.3.1 iso.3.6.1.2.1.1.9.1.2.2 = OID: iso.3.6.1.6.3.16.2.2.1 iso.3.6.1.2.1.1.9.1.2.3 = OID: iso.3.6.1.6.3.10.3.1.1 iso.3.6.1.2.1.1.9.1.2.4 = OID: iso.3.6.1.6.3.11.3.1.1 iso.3.6.1.2.1.1.9.1.2.5 = OID: iso.3.6.1.6.3.15.2.1.1 iso.3.6.1.2.1.1.9.1.3.1 = STRING: "The MIB module for SNMPv2 entities" iso.3.6.1.2.1.1.9.1.3.2 = STRING: "View-based Access Control Model for SNMP." iso.3.6.1.2.1.1.9.1.3.3 = STRING: "The SNMP Management Architecture MIB." iso.3.6.1.2.1.1.9.1.3.4 = STRING: "The MIB for Message Processing and Dispatching." iso.3.6.1.2.1.1.9.1.3.5 = STRING: "The management information definitions for the SNMP User-based Security Model." iso.3.6.1.2.1.1.9.1.4.1 = Timeticks: (5) 0:00:00.05 iso.3.6.1.2.1.1.9.1.4.2 = Timeticks: (6) 0:00:00.06 iso.3.6.1.2.1.1.9.1.4.3 = Timeticks: (6) 0:00:00.06 iso.3.6.1.2.1.1.9.1.4.4 = Timeticks: (6) 0:00:00.06 iso.3.6.1.2.1.1.9.1.4.5 = Timeticks: (7) 0:00:00.07 iso.3.6.1.2.1.11.1.0 = Counter32: 24 iso.3.6.1.2.1.11.2.0 = Counter32: 25 iso.3.6.1.2.1.11.3.0 = Counter32: 0 iso.3.6.1.2.1.11.4.0 = Counter32: 0 iso.3.6.1.2.1.11.5.0 = Counter32: 0 iso.3.6.1.2.1.11.6.0 = Counter32: 0 iso.3.6.1.2.1.11.8.0 = Counter32: 0 iso.3.6.1.2.1.11.9.0 = Counter32: 0 iso.3.6.1.2.1.11.10.0 = Counter32: 0 iso.3.6.1.2.1.11.11.0 = Counter32: 0 iso.3.6.1.2.1.11.12.0 = Counter32: 0 iso.3.6.1.2.1.11.13.0 = Counter32: 34 iso.3.6.1.2.1.11.14.0 = Counter32: 0 iso.3.6.1.2.1.11.15.0 = Counter32: 0 iso.3.6.1.2.1.11.16.0 = Counter32: 38 iso.3.6.1.2.1.11.17.0 = Counter32: 0 iso.3.6.1.2.1.11.18.0 = Counter32: 0 iso.3.6.1.2.1.11.19.0 = Counter32: 0 iso.3.6.1.2.1.11.20.0 = Counter32: 0 iso.3.6.1.2.1.11.21.0 = Counter32: 0 iso.3.6.1.2.1.11.22.0 = Counter32: 0 iso.3.6.1.2.1.11.24.0 = Counter32: 0 iso.3.6.1.2.1.11.25.0 = Counter32: 0 iso.3.6.1.2.1.11.26.0 = Counter32: 0 iso.3.6.1.2.1.11.27.0 = Counter32: 0 iso.3.6.1.2.1.11.28.0 = Counter32: 48 iso.3.6.1.2.1.11.29.0 = Counter32: 1 iso.3.6.1.2.1.11.30.0 = INTEGER: 2 iso.3.6.1.2.1.11.31.0 = Counter32: 0 iso.3.6.1.2.1.11.32.0 = Counter32: 0 iso.3.6.1.4.1.8072.2.1.1.0 = INTEGER: 43 iso.3.6.1.6.3.10.2.1.1.0 = Hex-STRING: 80 00 1F 88 80 28 B8 EF 53 96 13 43 38 iso.3.6.1.6.3.10.2.1.2.0 = INTEGER: 6 iso.3.6.1.6.3.10.2.1.3.0 = INTEGER: 1 iso.3.6.1.6.3.10.2.1.4.0 = INTEGER: 1500 iso.3.6.1.6.3.11.2.1.1.0 = Counter32: 0 iso.3.6.1.6.3.11.2.1.2.0 = Counter32: 0 iso.3.6.1.6.3.11.2.1.3.0 = Counter32: 0 iso.3.6.1.6.3.15.1.1.1.0 = Counter32: 0 iso.3.6.1.6.3.15.1.1.2.0 = Counter32: 0 iso.3.6.1.6.3.15.1.1.3.0 = Counter32: 0 iso.3.6.1.6.3.15.1.1.4.0 = Counter32: 0 iso.3.6.1.6.3.15.1.1.5.0 = Counter32: 0 iso.3.6.1.6.3.15.1.1.6.0 = Counter32: 0 iso.3.6.1.6.3.15.1.2.1.0 = INTEGER: 0 iso.3.6.1.6.3.16.1.1.1.1.0 = "" [...] --- Quote End --- So it is ok for the system mibs and some other infos, but nothing about my network interface (eth0)... My (simple) config : --- Quote Start --- rwcommunity private rocommunity public sysServices 2 sysDescr XXX interface eth0 6 100000000 --- Quote End --- As you can see I tried to add "interface eth0 6 100000000" to my conf file but it is not recognized by this version of net-snmp I can't figure out if net-snmp is able to "automatically" retrieve network interface, or if my issue is related to the nios2 linux environment I use. I googled a lot for nothing. Do I need to add a MIB in menuconfig (I tried mibII/ifTable mibII/interface mibII Rmon if-mib...) ? Do you have any idea ? Thanks - Altera_Forum
I think that I need succeed to add modules in menuconfig : mibII/ifTable mibII/interface mibII Rmon if-mib
But there is compilation errors, and if I let only mibII/interface snmpd hangs the system ... - Altera_Forum
Hello mr zben
try add your mib at computar that you do snmpwalk (i dont remenber what directory but look like Mibs) and add that mib at /user/net-snmp/.../mibs good luck Franz Wagner
