16 years ago
NEEK Standard System with VGA Controller
I'm looking for NEEK Standard System configuration (EP3C25) (like: http://www.nioswiki.com/@api/deki/files/115/=neek_ocm_spi.zip) with a VGA Controller (like: http://forum.niosforum.com/forum/index.php?act=attach&type=post&id=57) already implemented and connected.
Has somebody tried this controller on NEEK ?
I have problems making the connection with the top level entity.
Thanks in advance
D.
    Thank you Kazu.
    I'm going to try the "video pipeline" like the one for LCD display, but altering and adapting for the VGA. I assume this would work out for the vga part.
    I also going to try the methode with the VGA controller and connecting the encoded output to the HSMC.
    Durb.
    Hi all, I wish you a Happy New Year!
    I would like to ask for help with some explanation of the VGA controller (http://forum.niosforum.com/forum/index.php?showtopic=3165) (http://forum.niosforum.com/forum/index.php?showtopic=3165%29).
    I once again attached the picture which shows the bottom of block diagram of the top lvl entity - sysfile.jpg
    I would like to know what the outputs m1_/m2_from_the_vga_controller mean and where do I have to place the assignments, respectively.
    Furthermore I do not exactly know the difference between the output sync_n_from_the_vga_controller and sync_t_from_the_vga_controller.
    Any advice would be appreciated.
    D.
    I have put the VGA controller aside due to some complications and trying the video pipeline method for controlling the external monitor.
    How do I get 10-bit wide output of the VGA Data with the components which are also used to control the LCD display (8-bit output data) of the NEEK? Actually thats my problem at the moment.
    I will be grateful for some advice.
    D.
