11 years agoNeed PCIe Driver of X86 PC for DMA Read/Write Support on QSYS Cycleon V FPGA System
I am working to develop PCIe Driver on X86 Linux System for Cycleon V FPGA System. I have included DMA Read/Write Control in FPGA System as well. Now, I want to use standard DMA Read/Write...
11 years agoShould work.
The DMA engine needs to do correctly sized avalon burst cycles into the pcie avalon slave. I did pipelined avalon reads from the internal memory block. Didn't bother overlaping the reads and writes - allowed a simple 64-bit wide memory block be used ho hold the data. I dual ported that memory block to the avalon bus and used it to hold the addresses, length, sttaus (etc). Gave me a multi-channel dma controller (round robin, doing one burst per channel) for not much resource use.
