20 years agoNeed ideas on solving a weird LAN91C111 problem
I have a dual processor design with two /f cores. One processor, cpu_fifo, pulls data out of a fifo that is filled by a VHDL block receiving data from some proto pins. It copies the data into a share...
20 years ago --- Quote Start --- originally posted by jesse@Jun 19 2006, 03:32 PM i can't explain the alternating behavior you are seeing; however, the clock-cycle count being proportionally higher is to be expected. that is to say, increasing the clock-speed should help you with software/packet construction tasks, but the interface to the ethernet chip will not improve.
why? the 91c111 is a pretty slow chip; a while ago we had to dial-down the performance to it using avalon wait-states (can be seen in the components/altera_avalon_lan91c111/class.ptf file) to ensure that proper timing to the chip was met in all circumstances, including dma transfers. since this time-delay is fixed, the generated sopc builder logic will insert additional delay cycles to ensure that timing to the chip is met regardless of input clock-frequency.
i'd suggest some profiling - gprof to start - between 50/100 systems to see where the discrepency is with these occasional long-latency packet transfers.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16256)
--- quote end ---
--- Quote End --- I've only used the performance counter so far, I'll look into gprof to see what I can figure out with that. This is what my LAN91C111 class.ptf file says: Read_Wait_States = "20ns"; Write_Wait_States = "20ns"; Setup_Time = "20ns"; Hold_Time = "20ns"; Is that what it should be? 20ns doesn't seem that extreme.
