11 years agoNAND Flash Booting
hello, Am facing problem with NAND Flash booting. Am able to boot the preloader successfully using nand. Am using s34ml01g1 NAND flash. What i have done is: 1) I have placed preloader-mk...
11 years agoI am using the same NAND device but am using the 2G size and think I have a similar problem that you were experiencing. The preloader runs fine but Uboot does not run. See the macros that I changed to support the device I am using. Did you ever figure out your problem?
# define CONFIG_SYS_NAND_PAGE_SIZE 2048 /*512*/ # define CONFIG_SYS_NAND_OOBSIZE 64 /*16*/ # define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) /*(32 * 512)*/ /* number of pages per block */ # define CONFIG_SYS_NAND_PAGE_COUNT 64 /*32*/ /* location of bad block marker within OOB */ # define CONFIG_SYS_NAND_BAD_BLOCK_POS 0 /* environment setting for NAND */ # ifdef CONFIG_ENV_IS_IN_NAND # define CONFIG_ENV_OFFSET (0x00080000) # endif
