10 years agoMy AXI4 Lite slave hangs CPU after read. Write transactions work correctly
Hi, I have ported my AXI4-Lite to IPbus bridge from Zynq to Altera Cyclone V. Unfortunately, it behaves in a strange way in Cyclone V. Tests have been done with "devmem" tool in Buildroot comp...
10 years ago --- Quote Start --- That's exactly, what I have used to design my bridge. See http://opencores.org/websvn,filedetails?repname=ax4lbr&path=%2fax4lbr%2ftrunk%2frtl%2faxil2ipb.vhd ;) However this link is a "moving target"... BTW. In this document there is nothing about avoiding combinational connections between input and output signals. That's why I have run into this incompatibility. Thanks, Wojtek --- Quote End --- Can you show the combinatorial connections? Now I already perused your code. Immediately I can't make much of it as it is rather complicated. I had expected to see a state-machine ... a state machine is worth a thousand equations Regards, Jos
