16 years agoMultiple NIOS same memory code
Reading the tutorial about Multiprocessor systems, i understood that it is not possible to have multiple NIOSs executing a same program code from the same memory space. Does anybody know what is the problem with this? In fact, I would like to have MicroC/OS-II in a shared memory zone and then multiple processors accessing the OS's functions... Thanks4 Replies
I don't think there is anything that will stop that working, however it would require extreme care as all the data would have to be separate.
You might manage that with a fully custom 'OS' but the commerial OS won't run that way. Clearly 'tightly coupled' instruction memory can only be shared between 2 cpu - and then only if initialised in the fpga image. On-chip instruction memory accessed through the Avalon MM interface will probably give a performance penalty when the same block ends up being accessed by more than one cpu concurrently (compared to each using a separate block - but tightly coupled is much better anyway). External (SDRAM/DDR) memory accesses won't be any worse than if the cpus are accessing different regions - indeed they may be better if the memory page doesn't need changing (CAS only access). - Altera_Forum
I'm not sure of understand what you wrote. What do you mean by "all the data would have to be separate" ? What would be the problem with an OS like µCOS/II?
If you're running code, you're correct...there shouldn't be any issue, but how would you avoid one processor stomping all over the other's stack/heap space. This is what dsl is referring to...
Cheers, -slacker - Altera_Forum
In fact, i shared the SRAM and SDRAM memories, the SDRAM is divided so each processor has its own space. Then i put the code sections (.text, .rodata...) in the SRAM and the stack and heap sections in the SDRAM private espace.
