16 years agoMultiple NIOS same memory code
Hello, Reading the tutorial about Multiprocessor systems, i understood that it is not possible to have multiple NIOSs executing a same program code from the same memory space. Does anybody know ...
16 years agoI don't think there is anything that will stop that working, however it would require extreme care as all the data would have to be separate.
You might manage that with a fully custom 'OS' but the commerial OS won't run that way. Clearly 'tightly coupled' instruction memory can only be shared between 2 cpu - and then only if initialised in the fpga image. On-chip instruction memory accessed through the Avalon MM interface will probably give a performance penalty when the same block ends up being accessed by more than one cpu concurrently (compared to each using a separate block - but tightly coupled is much better anyway). External (SDRAM/DDR) memory accesses won't be any worse than if the cpus are accessing different regions - indeed they may be better if the memory page doesn't need changing (CAS only access).
