14 years agomulticycle custom instruction not working
Hi All,
I am trying a 3 cycle (fixed) multi cycle instruction module with nios2. below s my interface. port ( clk : in std_logic := '0'; reset : in std_logic := '0'; clk_en : in std_logic := '0'; start : in std_logic := '0'; dataa : in std_logic_vector(31 downto 0) := (others => '0'); datab : in std_logic_vector(31 downto 0) := (others => '0'); result : out std_logic_vector(31 downto 0) ); here 'start' signal is never becoming '1' during my custom call. Also my module s getting only single cycle. if clk_en = '1' then if start ='1' then count <= 10; reg_out <= "0000010101001111"; elsif count = 1 then reg_out <= "1100110101001111"; count <= 0; else reg_out <= reg_out; count <= count+1; end if; here my reg_out always coming 0 count is also coming 0 always. (NOTE: from software side the instruction is going correctly as per (ug_nios2_custom_instruction.pdf) -- ie opcode is 0x32 N value s all 0s, a,b,c reg values are set proeprly. Also in sopc builder the added custom instruction is shwing its a 3 cycle fixed multicycle instruction.) Please help. Also i cud make combinatorial module work proeprly. Please help soon. Thanks, Preethi3 Replies
I'm no vhdl expert! but aren't you missing a test for the edge of 'clk' ?
I have the same problem. Same logic works when i implemented it as combinational, but since it has limitations i have to use multicycle custom instructions, however I couldn't get the correct result after running the project. In the Quartus ii timing simulation it shows the correct result after 4 cycles.
Thanks in advance for any support that you could provide. - Altera_Forum
Custom instruction Variable Cycles have 2 port: start; done. you don't have "done"
