16 years agoMulti Nios
Hi folks.
I have a strong doubt, that my will not work and i want to avoid it. In my system i have 2 Nios processors.I use EPCS flash memory, which stores 2 images. First is woking with data, that FPGA provides him.Second is responsible for communication. I use Ethernet communication and we purchased TCP/IP stack. I have to support the functionality of updating the first Nios,i mean to recompile all source code,to for Nios architecture and to prepeare NIOS1.flash image. Now the questions:- May I to update the NIOS image without updating FGPA program?
- Is there any problem to use described above topology of NIOS processors?
- If I receive the new version for NIOS1 via Ethernet link, is there any problem to burn it to Flash(EPCS) memory?
Slava, I'm using just one Nios but changing the content of EPCS over ethernet is implemented there.
I will try answer your questions. 1. Yes it's possible. You have to know the start address of the firmware image. The best is when it starts at a sector boundary. 2. No idea 3. No you can use the alt_write_flash_block() or alt_write_flash() function from Altera HAL API. Data transmission is more save if you use an additional checksum. Last Question: I think you have just one bootloader because only one EPCS device controller core can be instantiated in each FPGA design. The boot loader code is stored in a small onchip RAM in epcs controller. Jens - Altera_Forum
I am developing a multiprocessor project to compress the image. My proposed task is: I have designed two processor sytem on de2-70.Now I want each processor to compress half part( half horizontal slice) from the image simultaneously. I have tested the apllication for single processor image compression(png to jpeg image conversion) Can you please provide any suggestion regarding above task? I want to how to achieve interprocessor communication? - Altera_Forum
Actually, I think, more efficient solution will be to implement the compression algorithm by HW. I mean VHDL code. I still a new in Nios ll, but l know, you can determine shared memory between your processors.
You could map a block of M9K memory as tightly coupled data memory for both cpus.
Use Decker's algorithm for mutual exclusion.
