Amir3
4 years agoMulti Core - unable to burn apps to Flash (No CFI table found)
Hi, everyone,
I created in QSYS a Multi-Core system that currently contains Master and Slave (total 2 CPU). I can burn the applications of each CPU using the Nios command shell by the commands:
hareesh
4 years agoHi Amir3,
can you please respond whether you are still facing the issue or should i close the case
Hareesh B.
