Multi Core - unable to burn apps to Flash (No CFI table found)
Hi Amir3,
Providing procedure document for QSYS a Multi-Core system (create multiprocessor NIOS-II system). please find bellow given link and follow the procedure.
link :
Hi Amir3,
Since I had provided you the solution and did not received any feedback from you, I shall set this case to close pending. If you still need further assistance, you are welcome reopen this case within 20days or open a new case, some one will be right with you.
I shall set this case to close pending,
If you happened to close this case you will receive a survey. If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Hareesh B.
- Amir34 years ago
Excuse me, but referring me to a general U.G that does not specify the way of programming that I am trying to perform is not a solution, especially since you referred me to a Multi-core U.G from 2011 when there is a more up-to-date guide from 2017.
- hareesh4 years ago
Qsys System Design Tutorial, multi core reference design, and video tutorial link sharing here. please go through it.
Qsys System Design Tutorial:
multi core reference design:
video tutorial:
