9 years agomSGDMA transfer from DDR3 using FPGA2HPS-SDRAM interface
Hi, I am using a DE1-SoC board equipped with Cyclone V SoC, I have a custom circuit on FPGA with Avalon interface, I want to transfer some data from the DDR3 (of the HPS) to this circuit. I use...
9 years ago --- Quote Start --- Have you already tried this tutorial: https://rocketboards.org/foswiki/projects/datamover I will have to do this quite soon, but have not done it, so I would be happy to learn with you. --- Quote End --- Thanks, I will be too. This project use the F2H port instead of this F2SDRAM port, any way I will try it, and see if it is a good alternative.
