10 years agomodifying ghrd_top.v
I have a Cyclone V SOC Dev kit. I can copy the golden hardware design to temp and build it. I open qsys and add a Uart 232 hook it up then generate the code with no errors. I go to the pin planner and I don’t see the txd or rxd. How do I re-generate the ghrd_top.v? If I remove say the push button object it stays in the ghrd_top.v. So do I modify the ghrd_top.v manually? Thanks in advance PigletNo RepliesBe the first to reply
