12 years agomodified webserver - application crash under load
Hi, I write this post after some many hours of debugging without result... I have taken over the Altera webserver provided with the Stratix V GX devkit (not the one included in NiosII EDS)...
12 years agoHi again,
while debugging noticed a certain flow: at some point the Nios stops servicing HTTP requests, the PC asks for TCP retransmissions and than sends ARP packets for a while. After a number of ARPs the Nios starts sending flow control messages (in my understanding resume messages). Now if it sends resume messages I should understand it initially sent a pause request, which I don't see in the trace... I have attached a Wireshark trace of the session, from OK to failure...
60 6.778055000 Altera_1c:12:34 Spanning-tree-(for-bridges)_01 MAC CTRL 60 MAC PAUSE: pause_time: 0 quanta 203
0000 01 80 c2 00 00 01 00 07 ed 1c 12 34 88 08 00 01 ........ ...4....
0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0030 00 00 00 00 00 00 00 00 00 00 00 00 ........ ....
============== In a Qsys design without TSE MAC flow control the Nios also "hangs" but with the difference that the flow control message never gets sent. In both cases, while the Nios is in the complete silence state, 3 interrupts are continuously high: SGDMA RX, SGDMA TX and JTAG UART. ============== EDIT: I was able to capture the following exception: panic: unlock NET
dtrap - needs breakpoint
ip_exit: calling func 0xa028e88
netclose: closing iface Altera TSE MAC ethernet
ip_exit: calling func 0xa02da20
panic: unlock NET
ip_exit: calling func 0x0
in Objdump I have the following mapping: * 0xa02da20 - clock_c * 0xa028e88 - netclose Can anyone help me understand what's happening in this scenario?
