16 years agoMixed source/assembly list file from NIOS compiler?
Hi- Does anyone know the compiler command line option to produce a mixed C source/assembly list file? I'd like to compare the asm output for various NIOS custom HDL usages (memory mapped...
16 years agoThanks everyone for the clues and help (except for the not-so-helpful response). As with everything GCC, the answer is never in the most obvious place.
Here's how to get what I want: Go to the IDE menu Window / Preferences / NIOS II dialog. Make sure "Generate objdump file" is checked. The mixed C/ASM file for the **entire** project can be found in the "<project>\Debug" directory under the file name "<project>.elf.objdump". FWIW, I zeroed in on this solution because similar forum responses are searched and displayed at the bottom of thread page as each new response comes in. It's quite a nice feature! Even tangential responses seem to help. Thanks again, John Speth.
