16 years agoMixed source/assembly list file from NIOS compiler?
Hi- Does anyone know the compiler command line option to produce a mixed C source/assembly list file? I'd like to compare the asm output for various NIOS custom HDL usages (memory mapped...
16 years agoThe option you are looking for is "-S" for the nios2-elf-objdump utility.
$ nios2-elf-objdump.exe
Usage: nios2-elf-objdump <option(s)> <file(s)>
Display information from object <file(s)>.
At least one of the following switches must be given:
-a, --archive-headers Display archive header information
-f, --file-headers Display the contents of the overall file header
-p, --private-headers Display object format specific file header contents
-h, --headers Display the contents of the section headers
-x, --all-headers Display the contents of all headers
-d, --disassemble Display assembler contents of executable sections
-D, --disassemble-all Display assembler contents of all sections
-S, --source Intermix source code with disassembly
-s, --full-contents Display the full contents of all sections requested
-g, --debugging Display debug information in object file
-e, --debugging-tags Display debug information using ctags style
-G, --stabs Display (in raw form) any STABS info in the file
-t, --syms Display the contents of the symbol table(s)
-T, --dynamic-syms Display the contents of the dynamic symbol table
-r, --reloc Display the relocation entries in the file
-R, --dynamic-reloc Display the dynamic relocation entries in the file
-v, --version Display this program's version number
-i, --info List object formats and architectures supported
-H, --help Display this information
