10 years ago
missing socal folder
Hi!
I will be using DE1-SOC board for my bachelor's degree and Im learning on how to use it. I noticed that user's manuals are for version 13 of Quartus and current version is version 15. I have already encountered some differences that puzzled me but I managed to solve them with a bit of googling. Now Im at FPGA-HPS project and I get an error from command shell:
$ makearm-linux-gnueabihf-gcc -static -g -Wall  -IE:/Programs/altera/15.0/embedded/ip/
altera/hps/altera_hps/hwlib/include -c main.c -o main.o
main.c:6:25: fatal error: socal/socal.h: No such file or directory
# include "socal/socal.h"
compilation terminated.
make: ***  Error 1
I noticed that there are now two folders there: soc_a10 and soc_cv_av, which both include the missing files. What do these two folders mean? Which one should I use? Do I fix the header to match the new folder configuration?
Thank you for help!
    --- Quote Start ---
    I have the same problem
    --- Quote End ---
    I have the same problem and can not find a solution although I have followed everything closely in this discussion.
    I am using a DE0-Nano-SoC board and I wanted to bring the demo-Software in the Folder
    SoC/Beispiele/HPS_CONTROL_FPGA_LED/software up and running.
    Error:
    In file included from main.c:7:0:
    D:/intelFPGA_pro/18.0/embedded/ip/altera/hps/altera_hps/hwlib/include/hwlib.h:56:2: error:# error You must define soc_cv_av or soc_a10 before compiling with HwLibs
    main.c:8:25: fatal error: socal/socal.h: No such file or directory
    Has anyone found a solution?
    Many Thanks in advance, Reinhard
  • RRuiz5's avatar
    RRuiz5
    Working Makefile for 18.1 version
    TARGET = my_first_hps
    ALT_DEVICE_FAMILY ?= soc_cv_av
    SOCEDS_ROOT ?= $(SOCEDS_DEST_ROOT)
    HWLIBS_ROOT = $(SOCEDS_ROOT)/ip/altera/hps/altera_hps/hwlib
    CROSS_COMPILE = arm-linux-gnueabihf-
    CFLAGS=-g -Wall -D$(ALT_DEVICE_FAMILY) -I$(HWLIBS_ROOT)/include/$(ALT_DEVIVE_FAMILY) -I$(HWLIBS_ROOT)/include/ -I $(HWLIBS_ROOT)/include/soc_a10/
    LDFLAGS= -g -Wall
    CC = $(CROSS_COMPILE)gcc
    ARCH= arm
    build: $(TARGET)
    $(TARGET): main.o
    	$(CC) $(LDFLAGS) $^ -o $@
    %.o : %.c
    	$(CC) $(CFLAGS) -c $< -o $@
    .PHONY: clean
    clean:
    	rm -f $(TARGET) *.a *.o *~
  • RRuiz5's avatar
    RRuiz5
    LDFLAGS= -g -Wall
    ARCH= arm
    build: $(TARGET)
    $(TARGET): main.o
    %.o : %.c
    .PHONY: clean
    clean:
    This Makefile is working for me
    • HThie5's avatar
      HThie5
      @RRuiz5​ it the soc_a10 similar to the soc_cv_av (aka Cyclone V as on the de0 nano board) ?
