11 years agomissing socal folder
Hi!
I will be using DE1-SOC board for my bachelor's degree and Im learning on how to use it. I noticed that user's manuals are for version 13 of Quartus and current version is version 15. I have already encountered some differences that puzzled me but I managed to solve them with a bit of googling. Now Im at FPGA-HPS project and I get an error from command shell:$ makearm-linux-gnueabihf-gcc -static -g -Wall -IE:/Programs/altera/15.0/embedded/ip/
altera/hps/altera_hps/hwlib/include -c main.c -o main.o
main.c:6:25: fatal error: socal/socal.h: No such file or directory
# include "socal/socal.h"
compilation terminated.
make: *** Error 1 I noticed that there are now two folders there: soc_a10 and soc_cv_av, which both include the missing files. What do these two folders mean? Which one should I use? Do I fix the header to match the new folder configuration? Thank you for help!14 Replies
--- Quote Start --- I have the same problem --- Quote End --- Hello, I have the same problem and can not find a solution although I have followed everything closely in this discussion. I am using a DE0-Nano-SoC board and I wanted to bring the demo-Software in the Folder SoC/Beispiele/HPS_CONTROL_FPGA_LED/software up and running. Error: In file included from main.c:7:0: D:/intelFPGA_pro/18.0/embedded/ip/altera/hps/altera_hps/hwlib/include/hwlib.h:56:2: error:# error You must define soc_cv_av or soc_a10 before compiling with HwLibs # error You must define soc_cv_av or soc_a10 before compiling with HwLibs ^ main.c:8:25: fatal error: socal/socal.h: No such file or directory # include "socal/socal.h" Has anyone found a solution? Many Thanks in advance, Reinhard - RRuiz5
Working Makefile for 18.1 version
TARGET = my_first_hps ALT_DEVICE_FAMILY ?= soc_cv_av SOCEDS_ROOT ?= $(SOCEDS_DEST_ROOT) HWLIBS_ROOT = $(SOCEDS_ROOT)/ip/altera/hps/altera_hps/hwlib CROSS_COMPILE = arm-linux-gnueabihf- CFLAGS=-g -Wall -D$(ALT_DEVICE_FAMILY) -I$(HWLIBS_ROOT)/include/$(ALT_DEVIVE_FAMILY) -I$(HWLIBS_ROOT)/include/ -I $(HWLIBS_ROOT)/include/soc_a10/ LDFLAGS= -g -Wall CC = $(CROSS_COMPILE)gcc ARCH= arm build: $(TARGET) $(TARGET): main.o $(CC) $(LDFLAGS) $^ -o $@ %.o : %.c $(CC) $(CFLAGS) -c $< -o $@ .PHONY: clean clean: rm -f $(TARGET) *.a *.o *~ - RRuiz5
TARGET = my_first_hps ALT_DEVICE_FAMILY ?= soc_cv_av SOCEDS_ROOT ?= $(SOCEDS_DEST_ROOT) HWLIBS_ROOT = $(SOCEDS_ROOT)/ip/altera/hps/altera_hps/hwlib CROSS_COMPILE = arm-linux-gnueabihf- CFLAGS=-g -Wall -D$(ALT_DEVICE_FAMILY) -I$(HWLIBS_ROOT)/include/$(ALT_DEVIVE_FAMILY) -I$(HWLIBS_ROOT)/include/ -I $(HWLIBS_ROOT)/include/soc_a10/ LDFLAGS= -g -Wall CC = $(CROSS_COMPILE)gcc ARCH= arm build: $(TARGET) $(TARGET): main.o $(CC) $(LDFLAGS) $^ -o $@ %.o : %.c $(CC) $(CFLAGS) -c $< -o $@ .PHONY: clean clean: rm -f $(TARGET) *.a *.o *~This Makefile is working for me
